Is sundown audio really that amazing?
Op aq subs are decent but sound absolutely horrible, well the hdc3's do anyway....havent tried or heard the sdc's so no comment on them
you do understand that any subwoofer in the wrong box is going to sound horrible, right?
Never really cared about Sundown but after blowing two Crunch GP3k's I decided to try a "quality" amp and got a 2500D in a trade. Been running it for about a month now and I have to say I like it. So far it's withstood my apparently harsh conditions just fine. And I kind of like any company who's owner is willing to come to online forums and defend his product, so yeah, I think Sundown really is that amazing :p
Glad you like it -- the GP3k amps have spring clips on the FETs so I'd guess vibration is your issue and the FETs snapped off and thus the amp blew. For this reason we don't use spring clips on the FETs and add a bunch of extra screws to the board itself to prevent this type of failure. dB-R has confirmed that ~75% or so of the amps he sees are vibration related regardless of what the failure looks like on the surface.
;7427646']im getting ready to purchase a pair of sa8s... gonna be my first experience with their subs. i hope they live up to the hype and survive the 2kish im throwing at em //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Be sure they are the newest revision if you plan that type of abuse -- we've beefed up the leads and spider a bit on the most recent production run.
off topic.
jacob, i do have one MINOR suggestion for you. the blue led's on your remote gain controller's are way way too bright. i have had to put black tape over mine to keep it from blinding me at night.
off topic.jacob, i do have one MINOR suggestion for you. the blue led's on your remote gain controller's are way way too bright. i have had to put black tape over mine to keep it from blinding me at night.
yep and that is about the only down side to Sundown.
Good point though
Yeah, I really hate the design of the GP3k. I attempted to repair the first one I blew and boy was it a PITA. It has 3 screws that screw the board to the heatsink, other than that, it's only the fets that hold it in place so the legs on those things must take an awful beating. I did have the amps mounted to the top of my enclosure however, it was double baffled (so 1.5" of MDF) and I thought that would be fine, but apparently not. In any case, before I installed the Sundown I cut out another piece of MDF to mount the amp to and actually put a good amount of 1/4" foam between the amp board and the double baffle of the enclosure. So far so good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I really dont think that the spring clips are the problem, i think it was the mounting on the box that killed your GP3k. Zapco, AQ, DD, Incrimanator,American bass, arc audio, and maybe more used spring clips also.
If you would like to verify about spring clips vs. bolt down contact dB-R Electronics. He has worked on 100s or 1000s of amps both ways and statistically spring clip amps fail more often than bolt down at the FET legs. Many companies use them as they are quicker upon initial build and also can be used to mount FETs vertically much easier for a narrower case.
Reliability CAN be pretty good with spring clips IF, a big IF, adequate support is given on the board (I have seen some of the new IA boards and they DO offer good support so they are a good example of doing it well) -- which often it is not; as is the case with the GP3k. Regardless, though, bolt down has the statistical reliability advantage against vibration per dB-R.
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
Tbsh
Hai.
Tbsh
Melbourne, Fl
RAM_Designs
