Is sub power handling overrated?
Aren't power hungry subs that take 2-3k really inefficient? Why buy a sub that takes 3k to get it moving vs a sub that only takes 1k to get it moving? It seems like cone area is far more important in a lot of cases. Your car electrical system can only get so big and that determines how many watts RMS you can run.
I just prefer to buy one larger sub to two smaller because of price. I can get an 18" for 400 bucks that handles the same power and has more cone area than 2 12's when the 12's are 250 a piece.
True but it usually takes 6-7 cubes for an 18 vs 2-3 cubes for a 12. You get a little more cone area with an 18, but with 2 12s you get more thermal power?
True but it usually takes 6-7 cubes for an 18 vs 2-3 for a 12.
Also get over twice the cone area.
We got a response saying somewhat and depends on so many thing, I would like some elaboration? Becasue I'm kind of curios about this as well.
I meant 6-7 cubes for an 18 and 4-6 cubes for 2 12s. I'm curious to know the advantages of having two magnets vs one.
Well cone area and stuff, matters if you're limited on space
for example I run 1 15, because my trunk is very limited on space.
I'm pushing it space wise already.
To get the loudest you possibly can, you want to maximize cone area, mechanical power, and subwoofer efficiency. The only way to get louder after maximizing these is to get a bigger amp and run more watts after upgrading your electrical system.
i thought we were talking about power handling? not SPL. things like rms, max those kind of ratings. not sure how we got into cone area and such
Power handling is directly related to SPL as is cone area.
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
966
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
421
Magnus
U mad brah?
Magnus
Midwest
THATpurpleKUSH
    May 31, 2024
    May 24, 2024
