i said it depends on so many things cause it doesnt matter what the sub is rated at. take 2 12" 1000rms subs vs 1 15" 3000rms subs. give them the same amount of power and the 2 12s may be louder due to cone area. give the 15 the full 3k and it may be louder cause of power. also, it depends on the enclosure. ive had a single 15 do 150s on 4kw and ive had 2 12s do 150s on 4kw. if you can design and build a good enclosure, you can get any sub loud.Also get over twice the cone area.
We got a response saying somewhat and depends on so many thing, I would like some elaboration? Becasue I'm kind of curios about this as well.
all depends on the box and the powerso you think a ssxxx is gonna meter louder then say a dd 9500?
cone area is nice for hairtricks. i like getting big numbers with smaller setups. i did a 149.x with a single 12 before. couldnt do a hairtrick but could get loud. coming soon is a dual 10s 150+ setup for meguys i have a 03 tiburon i have had a few dif 15s . all have been ported , then i went to 1 12 tune low then i went to 4 12s sealed. i have to say the cone area is a major part of moving air . im sure one big sub with the right power would b better then a few smaller subs with less power. i spent alot of time thinking about what i want to do as far as with my new setup. i luve the conea area even though i had to go with a sealed setup. i do have a issue with the lower notes but i would never run a single sub set up again.
Isn't tuning low for hair tricks? Cone area won't do much good for hair tricks if you are tuned to 45-50hz.cone area is nice for hairtricks. i like getting big numbers with smaller setups. i did a 149.x with a single 12 before. couldnt do a hairtrick but could get loud. coming soon is a dual 10s 150+ setup for me
pretty much. set a goal for a setup and try to hit that goal. imo equipment is 50% and install is 50%. even with a great box, cant get great numbers with ****** equipment and vice versa.So you say to basically do what you want and as long as its quality equipment and a quality install it should do well?
tuning low and cone area. when i had 2 18s, i could do a hairtrick at 30hz-50hz. granted the higher frequencies didnt give the best hairtricks but they still got it up.Isn't tuning low for hair tricks? Cone area won't do much good for hair tricks if you are tuned to 45-50hz.
