swollen_cu
Hi, I have a Kinetik hc800 battery and don't know if it's really bad.
It's currently resting at 12.9 Volts which I think is good.
When I brought it to Autozone, Pepboys, and O Reileys, All 3 stores tested it and said it was a
BAD battery. The measured cca when they test it was around 230 CCA.
Is there a special way to test these batteries at the store or is it just a normal typical test.
When the stores tested it, I told them to type in 750 cranking amps.
Is that the correct way to test these kinetik batteries?
Thanks in advance...
