Is knukonceptz good stuff?
All there Wiring/ Block etc is Nice. But RCAs are very very Poor made. Connection from Wire to Piece fall off Twice. Had to Re-solder...after the 2nd time falling off I spent 300 Plus on better RCAs.
Inline fuse holder? Give us some hints, when will they be available?
Yep, Inline fuse holder, will match the rest of the line (Kompression Fittings), smoke colored housing, waterproof...etc. Thats all I can say till production is wrapped up. We're looking into some patent information based on its configuration.
Should be available for purchase in late April/early May.
So it will basically look like the currrent inline fuse holder other than being smoke colored and having compression fittings or will it look totally different?
i run a lot there stuff. the only thing i dont like is there in line fuse holders. its not good access to change the fuse out in tight spaces. but i love there wire....have a lot of kollosus in my truck //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and regards to the RCA's of the 5 series the lower two models use molded ends, the two mid/upper lines have the ends crimped onto the "legs" (with teeth) then soldered and shrink taped. To remove any ends requires a good amount of force to break the crimp or the molded plastic. The cables in any RCA range from 18-30 gauge and the solder joints are not meat to be strain releif
No one has even damaged an eKs RCA, those use dual set screws, solder, and silicon to secure the massive cable.
The in-line holders can be a ***** in tight spots but well worth it imo, how often are you honestly changing fuses anyway? Its not like its a regular thing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif BTW I love the Fleks cable that I ordered from Knu, got it like 2 days after it shipped, maybe 1 lol. Love it!!!
I got Krystal cables and the jacket at the plugs split on both pair. The green rubber. The distro block screws broke from the fuseable end on the bottom side under the tape and the little screws are junk now. I like the way the connections are made. Good on a budget but I'm going Stinger on final installation.
Generally, you could say they are similar in form. They assemble together similary, but thats about it. Nothing on the current fuse holder is used on the new model. We will still offer the current model and you'll understand why once the new one is released (No LED's or fancy display's either) We've learned in our test market no one wants a $50 block
I like knu products alot. I'm not a big fan of compression fitted stuff though so the konfused terminals and distros aren't my thing (I felt this way before knu used the compression fittings). I will say the konfused battery terminals are darn sexy and will not come off a battery post. I loved the look, wish they were set screw design (I'm just a set screw guy). the kolossus wire is 2nd to none, period. Fuses hold up much better than any other company's (compared to streetwires, tsunami, etc).
Yes, I thought that fancy block would be a no seller. I personally do not like flashing lights or neon colors in my vehicle. I hate most of the new HU's for that exact reason.
I got Krystal cables and the jacket at the plugs split on both pair. .
Jacket split in the middle of the Y? Only way I can see that occuring is from making them extend too wide apart. I know some try to get a 4 channel cable to work on two 2 channel cables and its not designed for that. The new Karma's have longer "legs" to allow more play
The distro block screws broke from the fuseable end on the bottom side under the tape and the little screws are junk now. .
How did this occur? not placing blame, want to know for any future revisions if required. We have spare parts if you need them, email and we can get them to you.
Lifted07Sierra
Lifted07Sierra
modest, ca
KINGDELL91
