is it safe to wire a audiopipe ap 1000 d down to a half ohm?
i dont even know where the engine ground would be though.loland how much for your kits though?
- Follow the wire connected to the battery, and you will find where they have it bolted to for your stock connections... Also - I noticed you say a few things asking about "series wiring" - SERIES wiring of any voice coils will double the impedance load, so that would take you up to 4 ohms which would NOT give you more power. Stick with voice coils parallel to each separate amp @ 1 ohm & set your gains properly = That is the MOST you are going to get from that setup until you upgrade your amp(s)
There aren't many wires coming off the amp. There's: power in (12V Batt +, usually the big red one), power out (Ground, usually the big black...
Hello, I am getting ready to install my 3000 watt taramps and 2 15s in an expedition. I am a little hung up because my old car had a 220 amp...
Cant use the scope because the amp is plug and play. Can only set it up by ear. Will I hurt the speakers by playing a 1000hz tone at 75% volume...
american bass91
newport news,VA
NIHL8ION
