is it safe to wire a audiopipe ap 1000 d down to a half ohm?
i dont even know where the engine ground would be though.loland how much for your kits though?
- Follow the wire connected to the battery, and you will find where they have it bolted to for your stock connections... Also - I noticed you say a few things asking about "series wiring" - SERIES wiring of any voice coils will double the impedance load, so that would take you up to 4 ohms which would NOT give you more power. Stick with voice coils parallel to each separate amp @ 1 ohm & set your gains properly = That is the MOST you are going to get from that setup until you upgrade your amp(s)
american bass91
newport news,VA
NIHL8ION
