is Acrylic a good material to build a sub box out of?
if your in san jose go chek out guru electronics and he has alot of bobby gately boxes and you will be able to see the difference between the 2...... wood is going to be way cheaper but plexi is going to be stronger... will not warp or get wet and.. but it is alot more expensive.... so if your looking for something cool to show off go with plexi. but if you are under a strict budget go with wood....
if you are making it yourself i would not suggest it with plexi because of the fact, that is you mess it up or dont know what you are doing then you are wasting alot more money.
if it is wood you can fix your mistakes and you can learn from that.
hope it helps
Pineapple
Pineapple
San Jose, CA
smurf
ThxOne
    May 25, 2026
