Interchangable Port Box- Round 2
I knew you did your own work, just kinda joking. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif BUT, if you ever wanted some work done, you know where to find me...
LOL
Dont you?
The ports more than likely will no rattle. There is actually a support piece under the bottom of the inserts, and once mounted in, those things arent going anywhere. As far as sealing, shouldnt need anything because of the tightness you can get the screws, but you could always add some foam tape between the front port piece and the area it mounts to.
Your builds never cease to amaze me. The precision and accuracy of your cuts and router work is just absolutely amazing. There are tons of box build logs on here, but yours always stand out even on the simplest designs, excellent work once again.
Same goes for me, as youve done three of my builds. lol. how you do it, i know not.
I guess it gets pretty easy after awhile. Kind of just get in a routine, LOL.
that box is ****ing badass bro!
Thanks a lot man. I wish I was in to competing and stuff, a setup like this sure would be pretty sweet.
Basically you drill a hole, and they screw into the material. They work awesome. I dont have anymore, so I cant take pics, but I bet if you googled them, you can find some info...
well thanks, what do you think about using them to hold in a sub? Stable enough?
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
794
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
975
949
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
bjfish11
FisherCustoms.com
bjfish11
Garden Plain, KS
bjfish11
maylar
    Jun 2, 2024
    Jun 1, 2024
