Interchangable Port Box- Round 2
what are these called?
So pretty, your work always seems so flawless, what do you do to keep it so flawless. It's like a robot cutting all the pieces and attaching it together, no mistakes at all. Looks sick! I like the plexi logo on top.
Thanks man. I really appreciate it. Basically, it just comes down to a lot of practice and patience.
The are called threaded wood inserts IIRC. They are much better than T-Nuts in my opinion. I always have bad luck with T Nuts not staying in the wood. These things work so awesome.
Humm, threaded wood inserts, dont have to go all the way through the baffle like a T-nut, therefore will stay airtight. Good to bring a great idea to light //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif. Thanks guys.
FatTony, yep thats the finished product. He actually had be add a second panel to the back. He is mounting a large amp back there and wanted the extra strength, but no carpet on this one.
Thanks Meade... LOL, if you ever need a box, hit me up. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Good to see you back PV.
BigBang, Chris actually gave me the idea to use these, too bad I cant take credit, but yes, they work awesome.
Dleccord, I have purchased them at Lowes before I believe, so you should be able to find them almost anywhere.
I have used threaded wood inserts before, mine were made of brass though, came from Ace Hardware. They were through-bolt...Might consider some non permanent thread lock compound if your worried about air. Will help keep bolts from loosening with vibrations over time. I like them better than t-nuts also.//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
They were just like those, but different!
w3rd up man! I do my own stuff but i wouldnt be ashamed to have some of your skills sprinkled somewhere around my house //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I knew you did your own work, just kinda joking. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif BUT, if you ever wanted some work done, you know where to find me...
He uses trupan light //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
LOL
I'm not impressed.........NOT!!
Looks great.. I was wondering if the "port inserts" rattled because they were off the bottom of the box a bit?
How did you seal the "port insert" to the box?
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
855
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
bjfish11
FisherCustoms.com
bjfish11
Garden Plain, KS
bjfish11
Decebal
    Jun 10, 2024
