integra trunk?
  • 2
what i would do is make the fiber glass tub then remove it from the car and fill it with water, sand, or whatever and you will be set.
thats a good idea to pull the glass shell out , but i was trying to get the sub before i did all that to be a little bit ahead of the game, if you know what i mean.
well im almost positive that you will have too much room in that shell and will end up filling it to fit the requirements of the sub(s) anyways, so you should be able to just buy your sub(s) and end up with more room than you need. go to and see what he did about finding the volume of his shell. this is Josh, Mike's brother.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
785
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
hondamanwill
hondamanwill
Wisconsin
gunny86
    May 31, 2024
    May 24, 2024
