Installing help
Check your wiring again. No power, no light would seem to indicate that you have an issue with your power wire. Can we assume that the ignition key is in the on position? Did you check the fuse for the radio? Also, check your ground. Go over the wiring diagram that came with the stereo harness and the one for your vehicle. Good luck.
Deehousley6
CarAudio.com Newbie
Deehousley6
Coushatta, la
huberoy123
