installing h/u
pj_chevy03
please ban me
928
Alabama
i'm going to be installing a h/u for the first time pretty soon and was wondering if there are any precautions i should take so i won't short circuit something. i also would like to know if i should use the factory ground or use a new one. by the way its an alpine cda9830
unhook the battery (you NEVER know)
double check to make sure you connect the right wires together, and you can always use a voltometer (something like that) to make sure the connections are legit....if you have access to one then you should definately do it
i would recommend grounding straight from the hu, although i don't think it makes much difference, its just better to do a straight ground instead of going through more wire connections
as far as that, you should be good....good luck
Use a wire harness, and do all your crimping or soldering outside the car. Don't cut out the factory plug, and don't attach the harness until all the connections have been made and insulated.
Here in the USA. I am not sure the Honda Jazz exist. Ive never heard of one or have seen one. Though it looks very familiar to a Honda Fit that we...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
pj_chevy03
please ban me
pj_chevy03
Alabama
KaeZoo
    May 12, 2024
Brendon Jenness
    May 11, 2024
