installing a volt meter.
in the ashtray since i dont smoke
I didn't like the fact that I had two clocks about 3" from each other so I removed the lcd screen and kept the oem tinted look by double side taping the screen in from behind then ran to the HU for the on/off function. I like it it looks stock even when it's on people are always asking what's wrong with the clock?
well with your interior pick a panel that is easily/cheaply replaceable and with a little bondo work followed with some matching paint and it should look good, check ebay for the panel and modify that one not your stock that way at a moments notice you can go back to stock and if the modded panel looks good you can probably sell it.
I used velcro and put it on the panel near your right leg. It's where two panels snap together so I brought the wires up through the space and you cant see any wires.
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
VisceralSound
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
