installing a indash monitor
kpozr2
ok if i return my ///Alpine-9853 to best buy and get the $445.00 it cost my parents total last may for my birthday, and get it back in CASH, then put another $150.00 or so with it and order this
Alpine CVA-1004=600$
would i need to change my mounting kit, and how hard would it be to install by myself? are there any other cords i would need, and is it worth it to upgrade to that?//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
how are you going to get cash back for returning something that was bought 9 months ago? you can only return it for 30 days. if you got the warranty and its broke they will only give you a replacement or store credit.
I too see fault in this logic, but good luck.
i see 4 yr warranty agreement //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif cashed in my Ipod nano earlier this month that was under a 2 year. and i got the CONNECTIONS at bbuy //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
it'd probobly no more difficult to install than a regular HU, if it has a seperate brain, then that's not hard either, just a few more wires to run.
you'd probobly have to be pretty stupid to not be able to follow a few wiring diagrams.
a little patience and time is all it takes.
and it should fit right into your dash, they're made to fit the same size openings your regular headunit fit into.
good luck.
The CVA-1004 does not play CD's, DVD's, anything for the matter, its just a moniter. You would need to buy an Alpine changer, and a seperate DVD player if you care about DVD's, just incase you didn't know. I know it *****.
If you got that you would end up spending much more then 600 dollars, just for you info incase you were not aware.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
409
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
kpozr2
kpozr2
Iowa CIty, IA
theelfkeeper
    Jun 1, 2024
    May 31, 2024
