Installed everything today and AMP went into protect...
It is either the output fets are fried, or your output audio side driver is fried, sending a constant high signal to the gates of the fets on either positive or negative rail. Generally when there is a DC bias problem, the fet is not physically damaged, since there is no significant current flow unless it is shorting the SMPS.
Edit: And this is only if the driver is not being sent a constant on signal, so it could be a couple of things, but the most common is output fet failure.
how much would that be at a local repair shop about?
not if your amp is already blown..... i would imagine.
could try hooking up another remote or something. might need another deck.
could possibly do it off the bat?
gay that didnt work either //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif might need a new HU and see what it does then
must be the batts
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif//content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif//content.invisioncic.com/y282845/emoticons/swordfight.gif.e3de6069f3ffe402fc3ab4a827365101.gif//content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif
basscort2009
Banned
basscort2009
dallas tx
zack1442
