LosIsATool
I'm supplying
MS-8
Deadener
RCAs
12awg speaker wire 75ft
Big 3 kit
Mono block
Sub
Hertz splits
They are suppling
4 channel
16awg for rear doors and MS-8 signal
$500
Labor quoted on high side just in case
Deaden trunk and seal up front doors done right
Build mounts and seals for mids and tweeters done right
Run 4 runs of 12awg to the front doors
Run 2 runs to rear doors
Install MS-8(rear deck) powering rear doors with internal amp
Install 4 channel and mono(rear deck)
Build box for 8 and carpet
Build finish cover for amps and carpet on rear deck after tune is good
Install big 3
$900
I have faith this will be a good install, guy was a old school ISACA player
If I get time that I'm not counting on I'll do some of it so this is worse case senerio
MS-8
Deadener
RCAs
Big 3 kit
Mono block
Sub
Hertz splits
They are suppling
4 channel
$500
Install big 3
$900
