Johnsonmn2
Okay I have a 4awg wire setup to a distro block in the trunk with a 1000rms and a 200 rms amp. My inline fuse holder is only a 100a MAXI setup and it has never blown. My wire length is about 16' and i know that i will never get full power with this wire to both my amps. The fuses on my amps are 60x2 and 30x1 so the distro block is fused that way with 120a x1 and 30x1. Does it make a difference that my setup is fused higher at the block that at the inline? I was under the impression that at the distro you should fuse each channel per the amps rated fuse size. Should I get a completely new inline fuse rated at 150a then?
