Infinnity, Planet Audio, MB Quart, Boston - speakers
  • 1
subzero
(A) Planet Audio 4x6 two way component plates
(B) MB Quart RTE-20 (2 pairs)
© Infinity 6.5 Coax
(D) Boston
(A) USED
(B) BNIB
© USED
(D)USED
(A) $50
(B) $100 each pair
© $30
(D) $60
(A) $20 PER SET CONUS
(B) $20 PER SET CONUS
© $20 PER SET CONUS
(D) $20 PER SET CONUS
(A)
(B)
(D)
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
subzero
subzero
Chandler, AZ
subzero
    May 24, 2024
