In-line fuse blown. Amp not working.
Guess i gotta buy a meter. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. Just wanna know, is the amp ok? lol
of course. without turn on signal the amp can't turn on. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you want to do a quick test, run a wire from one of the fuses in the fuse box to the amp
The quickest way to find the problem is buy a dmm. You should own one anyway. Touch the neg pin from the dmm to the sheetmetal, and the positive to the rem wire terminal on the amp, then to the pos pwr terminal on the amp. If you dont see 12 volts at both terminals (with the engine off), you have a break in your circuit.
Check your grounds bro.Mossberg had this problem a couple weeks ago. Amp was going in and out, mostly out, and his fuse blew up under the hood. Amp was drawing extra current from the ground being loose. also you can use a short wire to go from 12+ to rem for testing.
nastc1
nastc1
Fleetwood, PA
nastc1
