im going to capet my box..help
No need to sand unless you have edges that don't line up. Carpet is nice because it hides imperfections well. I like to spray both surfaces that will be in contact then wait about 2 mins to let the glue tack up then it sticks real well. The only thing I don't like about carpeting boxes is that its really easy to make a mess. Make sure to not get the glue where it will show on the carpet, you will never get it off and if you rub it, you just get a flat spot. Its very easy to do this too.
I bought some glue from my wholesaler a few days ago. I don't know where you can find it though. But it comes out like a spider web. It is hard to explain how it looks. I found it was easier to control the spray and didn't stink up the house. It was fun to use! Way better than the 3m stuff IMO. If you want to search for it let me know and I will run down the basement and get the name.
Bout to get sum adhesive here in a couple hrs....shld i be good with the 3m 77 or jus spend the lil extra and go 90....i do have a slighty rough surface the carpets gona b stickn to. Heard the 90 is worth getn...any other tips wld b helpful 2
Well it turned out nicely for a first timer...seams could be better but it sure does look alot better than before..and besides not gona see seems in my trunk anyway. And yes my sub has a phat ***...pg xenon 1200.1 will be here to tomorrow! Sub was **** impressive off 500w...1200w should sound righteous.
Boss, awesome job
Looney_Tune
F**k How You Feel
Looney_Tune
Killeen,TX
Looney_Tune
