quad 12 vented box for truck
trying to build a vented box for 4 12's in an extended cab chevy truck but need help figuring out my internal volume and how large my port needs to be. im wanting the subs to fire forward and the vents to fire up toward the ceiling. im using 1" mdf and already have all the measurements for the box figured out, i need to know how much air space each divider will take up and also how much each baffold will use for the vents. any help would be appreciated.
that box is gong to be too small for 12s tens would fit better
I agree, before any displacement is taken into account you are looking at 7.15 cubic feet, which is about enough room for 2 of these 12s after you take displacement of vent and everything else into account.
thats the box dimensions i ahve for the 12's now but the box is sealed and i want to go vented. these dimensions are not exact of what i have now but they are close. and my air space is dead on for what the subs call for.
Per the manual you are correct, that is perfect for what they recommend in a sealed enclosure.
For a vented enclosure they recommend 12 cubic feet net for all 4 drivers.
ok 58 length 30 tall and 16 deep outside dimensions with 1" mdf is 12.7 now what?
find the inside dimensions, adding in three extra panels, or subtracting for them which ever makes more sense to you, then figure out the volume for one sub by dividing by 4.
then figure out the width you can make the port. There are several online calculators that can calculate port length, or I can if you post the volume or h x w x d.
You may find that the port is longer than you want. Since bigger boxes use shorter ports I may help to go with two subs per chamber.
Okay, here is what I have come up with, but please double check all of my math:
At 58 inches wide, all of out 1 inch MDF and a divider between all drivers, you would have 13.25 inches of width per speaker.
That said, in order to maintain ~3 cubic feet per driver after all displacement is taken into account you will need a height of 38 inches.
This accounts for the displacement of the port which will be 13.25 x 3 x 20 (12.78 sq inches of port per cubic feet...a bit on the small side but I am sure it will work.) at a tuning of 35Hz.
If someone could double check this I would appreciate it.
What I would recommend, if that height is a concern. is going against the idea of individual chambers and going with one common chamber, this will reduce a lot of the displacement.
Why 1" wood? It won't save you much, but utilizing bracing and 3/4" wood will net more volume. Not much, but in this case every little bit helps.
Also, depending on your amp setup I would just do a large common chamber enclosure. This will allow you to skimp a little on volume if you absolutely have to, all though I don't really suggest it.
Using a common chamber enclosure, with 3/4" mdf, proper bracing, and a single port you will find this to be much easier to fit.
chowdog
chowdog
Millbrook, Alabama, United States
pro-rabbit
michigan born
    May 14, 2026
michigan born
    May 14, 2026
