big scott
blazin low, and loud
hi guys,
i have read and watched vids on setting your amp. and i see everybody seems to use a different test tone. i have seen some use 40 hz so use 60 hz this is for setting sub amps.
does it really matter if i use 40 or 50 or 60 hz ??
also if you amp can produce more power then it says what do you do ?
like my 4ch amp is 100 rms per ch. but was told it will do like 125-150 per channel.
do you set it for 100 rms ?
and yes for right now im just going to set it with my ddm . next month im getting a o-scope .
also what freq. should i use for my front stage amp ? its powering my 6.5 and tweeters.
was just reading when doing a amp powering mids use a 1000 hz test tone. well what do i use for my tweeter side of my 4ch amp. also this amps has 2 gain pots 1 for ch1-2 and 1 for ch 2-3.
sorry guys but the more i read the more im confused.
