if i get an eternal battery
Looks like a group 47.
What alternator do you have? If it's stock, the battery is going to crap out on you sooner than later.
Typical battery life in passenger vehicles that I see every day is this:
Standard vented: 3 to 4 years. Possibly 5 if properly maintained
AGM: 5 to 6 years when maintined. Can still crap out earlier if abused, especially in marine applications.
The Kenetik is an AGM. If you run it with your stock battery too, it'll shorten its lifespan.
If you just have the stock alternator for th power you're running, it won't be able to keep up. You'll constantly be puling from the battery and it won't be able to fully charge and cycle correctly.
I'd give it a two year life expectancy. Three or four years if you kept it on a tender every night.
hey thanks for the respond! i was hoping at least 2 years to be honest! i have a stock alt with 110 amps running on a good battery. so if running on stock alt i should at least get 2 years out of it/.?
If you get an eternal battery, let me know first. It should last forever.
But on a serious note.. LTO batteries, the good ones, can extend cycle life to over 20,000 but you are paying for that life if you need the life.
Rougly two years, yes, but there are sooo many variables with battery maintenance
how do you maintain a battery? like clean the terminals? now that i think of it though if i did it every 2 years it would be pretty much adding up to a good alt x_x but i honestly dont know how long my car will last since the ***** is going i dont wanna buy parts for a car that will just die and i cant move anything to the new car.
Why not get this fixed, before putting the audio in?
***** is in the grands and the labor would be a big hole in the wallet, just trying to ride it out. at least audio i can take it out and put it elsewhere rather than car parts its specifically for my car only.
Noooo.....
Like not draining it down super low, not letting it sit for extended periods of time un-tended, and trickle charging it regularly.
My transmission is going too, but $10k in audio comes first //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Next is either rims/tires or a 4L80e transmission. Then it would be an 8.1L engine that I'd be saving up for
ekah
ekah
hawaii
adulbrich
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
