IDMAX v.3/ohm/amp question
  • 2
if you want to wire the sub up so the amp see 4 ohm then you will need to get the dual 2 ohm sub which can be wired either 1 ohm or 4 ohm. the dual 4 ohm can be wired to 2 ohm or 8 ohm.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
It also lowers the amps efficiency and raises the current draw.
646
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
439
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
yellowtrash
yellowtrash
Los Scandalous
liftedcj7on44s
