I want to downsize my 15CVX in my corolla
  • 4
Ok, I got the 2-SA8's in 1.3 cube box tuned to 34Hz after sub and port displacement.
The bass hits pretty good but not as hard as the 15. However, the sound quality is way better.
Now the question is, to get it louder, any recs on amp to get more power than my ZX1000 while not hurting my wallet? they are wired to total 2ohms. It seems like they want more.
Those 8's will take around 750 a piece no problem. With that being said, either upgrade to an amp that will do the power @ 2 ohms (1500w) or pick up an amp that is rated at 1 ohm or .5 ohm @ 1500w. The amp that does power at 2 ohms will be more efficient but cost more than an amp that does the same power at 1 or .5, but running an amp at 1/.5ohm will be harder on your electrical, so it's up to you.
These are the parts I think I need, can someone let me know if this looks right? Headunit: 9" Toyota Corolla 2003-2008 Android 10 QUAD CORE Door...
I just bought a pair of SoundQubed QP-MR6.5 speakers powered by my Taramps DS440x4. My 6x9s blew when I got the amp because I tried to tune the...
You're going to run into some issues with weight on the arse end of your car at some point and there's a limit to how much suspension...
Check out Focal. I believe they have direct replacements for many Toyota's...
Make sure they provide a warranty for theyre work and everything you buy.Ask to keep all the Boxes that every amp and speaker and sub comes in...
chay03
chay03
Oceanside, CA
Chappie
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
