I want to build a new system
Looks pretty **** only thing I would change is the sub amp. something probably around 2k cause thats a big ol sub, I dont have any experience with Ascendant but my guess just by looking is that they are pretty stout and would love a lil more power.
I would either go down to a 15 inch ported or throw more power at the 18 inch sub with the sealed enclosure. I would switch out that rockford for ct sounds at 1400.1D if your set on going sealed. make sure to have the big 3 done. Should be one nice sql system.
More power and get a ported box (not prefab) try a sundown amp so you dont have to upgrade you electrical
even if its a sundown amp... you still got to treat it out to dinner, take it out to movies and sh*t if you want maximum lovin" from it lol.
more electricals just means more "cushion for the pushin" for any amp.
also factoring in the amp draw from his 4 channel, both amps might be current starved with no electrical upgrades at all. sundowns are built like tanks and can handle low voltages fine but it doesnt mean it should be at a lower then optimal voltage, besides, with the high end stuff he's getting, i'm pretty sure he has the budget to do a good agm batt under the hood(maybe trunk too) and a big 3 kit.
I will be getting a extra battery also. I see I should upgrade my amp. That's something I will do down road already a lot $$ put into the system. My amp I have now birth sheet says 1360 I was trying to damage the sub with to much power I wanted to be right on point.
you strap 2 of your rockford amps together and that ascendant audio will eat it all up easily espcially if its in a sealed box, just keep the signal clean with proper gain and head unit settings and you'll be fine.
stlles
stlles
st louis
Jeffdachef
