I wanna put 2 15's in a chevy silverado 2D extended cab
heres one of many vids of what the crescendo can do, they will be available again at the end of September.. So join the waiting list.. like me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if you're gonna do 4 subs you're gonna need real power, which means at least an extra battery and 0 gauge which isn't cheap. I'd just suggest a quality 12 and only remove one seat. bobby32 on here is running a PSI reconed Audiopulse Axis 12 and doing high 140's.
... umm you could get all 4 of the 10s or 12s with the crescendo amp, wiring and a XS 3400 for well under 2k.. Im guessing 1500.. which is right in the ball park he wanted to be in .. its his call on what he wants to do with the rear seats..
Yea ive seen sundown SA12s do Hi 40s as well.. Everything is gonna be dependent on his install.. 2 lvl 3 15s,
1 lvl 4 18 with a sundown 1500d? that gonna put you at about 800 for subs and amp, and you wouldnt need another battery
Here's a box I put in a full sized extended cab Dodge (approx the same space):
Box was average sized for dual 15's, 8 cubes gross. I never tried putting the back seat back over the enclosure, but it might have fit.
Just take out the back seat and get it done with, you won't miss it. I know the my back seat area of my '04 dodge quad cab can fit 2 18's below the window line with ease.
I have had several set up's in my Excab ,dual 12s,dual 12s ported
singles,and now just a single FIQ ported.......One is enough for what I listen too and I wanted to save my back seat so I made a lift kit...
To do 2-15s you will have to dump the seat,personally I would never go that route because I like having a seat ,I like my stuff out of sight
of thieves too.......^^^^ that 8 cube box is nice,heavy as FK I would imagine ,Id tint the windows to wart off thieves again
If you mean the one I posted, it was destroyed in a car accident before I finished installing the stereo. Yes, it was heavy as fuck. Even bolted down, in the accident the box broke free from the false floor and smashed into the front seat, breaking it loose from the floor and pushing the seat into the dash. And that was before I even added the 150 lbs of subwoofer to the box. And people wonder why I harp on them to bolt their boxes down...
personally i would suggest 2 15's, more cone area than 4 10's and you wont spend as much on 2 15's as you would 3 12's
just saying more speakers means more money, and most likely need more power.. a single 21'' death penalty on a (insert budget friendly 2-3kw amp here) would be less than 3 12'' death penalty's alone
Another option if your willing to do a bit of work is putting the sub box where the center console is. Cant remember who it was, but someone on here had 4 12"s in that spot. You could do 2 or 3 and save your back seat.
If anyone knows who that was, post a link to the pics.
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
611
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
ccfromsd
ccfromsd
Houston, TX
chillin
    Jun 1, 2024
    May 31, 2024
