Going for Fi, BL or Q help me decide
JuniorSPL
title says it all - i was going to go for the almighty beast btl but came to the conclussion that my jeeps electrical status just cant give it what it needs power wise so i have decided to stick with fi but downgrade to a less power hungry sub. here are the specs and give me your opinion on what you would get, im looking for overall good sq but still get that hard thump when i want it.
BL18
DUAL 1 | DUAL 2
Fs: 33.2 Hz | 33.2 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.82 | 5.82
Qes: .32 | .32
Qts: .30 | .30
Mms: 302g | 302g
Cms: 0.88mm/N | 0.88mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 181.0 l | 181.0 l
Spl: 94.1dB 1W/1m | 94.1dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1000W * | 1000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-8cuft | 5-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft *
Q18
DUAL 1 | DUAL 2
Fs: 32.4 Hz | 32.1 Hz
Qms: 9.31 | 9.37
Qes: .48 | .48
Qts: .46 | .46
Mms: 341g | 347g
Cms: 0.73mm/N | 0.73mm/N
Vas: 149.7 l | 149.7 l
Spl: 92.0dB 1W/1m | 91.9dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
if anyone has ideas about amps to run with these please feel free to share, lookin to spend about 250-300 on the amp
thanks guys
JuniorSPL
JuniorSPL
Cali
JuniorSPL
