Trunk set up in a 2010 Dodge Charger..
Sub - SA-12 D4
http://www.db-r.com/sell/store3/index.php?main_page=product_info&cPath=1_6_17_32_33&products_id=17
I am little torn on this sub as an option as well...but I would have to rethink my amp choice?????
http://stereointegrity.com/product/mag-v3/
Amp - C2 Audio Threatcon 1800.1D
Box - 4th Order Bandpass through rear deck...
- With help from a member here..Thanks
2nd Battery - ?
- Not sure which, but my lights dimmed on my old set up... RF 500w Prime pushing a Memphis 10-PR @ 2ohm Volts dropped into 13.5v range at times.
This is for an every day set up. Just used to drive back and forth to work. 20-25min Drive at most.
Plans to run the SA-12 D4 at 2ohm from the amp rated at 900w @ 2ohm. Given the volt drop and SA's underatings... I'm all good correct?
Looking at a little under $400 total (-) the Box. Which I plan on putting together myself.
Thinking of 4th order, but open to suggestions. Want to keep it pretty simple and get some sound into the cabin more.
Sub - SA-12 D4
2nd Battery - ?
