i need to know Q
jojo1212
so i got my hands on a rockford p600.1 BD AMP unit
and wanna use it to drive 1 or 2 subs
my friend gave me yesterday a KICKER SOLO BARIC L5 12
he says its 1200 watts peak and 600 RMS
impedance 2 or 4 DVC
checked kicker's site, it says so
a performance certification came with the amp it says
RATED POWER = 600 w RMSx 1 @ 2ohms
MAX POWER = 2193
4ohms Load Mono = 325 watts x 1
2ohms Load Mono = 600 watts x 2
POWER OUTPUT MEASURED IN ACCORDANCE WITH CEA-2006 SPECIFICATIONS
441 RMS watts per channel @ 4ohms
731 total RMS watts@ 2ohms
Efficiency 78.295%
by the way this AMP isnt bridgable
the AMP page
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6&family_id=19&item_id=106477&locale=en_US&p_status=
my questions are
what does this 2 or 4 DVC means ?? the sub is 2 ohm dvc or 4 ohm dvc???
and i can i put 2 subs of this kind on my AMP??
i mean each channel on the amp will provide 600 rms
or each channel will provide 325 rms ???
when two subs are connected the amp will provide 1200 RMS
for both of the channels or 600 rms only ???
i hope im clear
exuse my english
so i got my hands on a rockford p600.1 BD AMP unitand wanna use it to drive 1 or 2 subs
MAX POWER = 2193
Efficiency 78.295%
the AMP page
my questions are
i hope im clear
exuse my english
1. The sub comes in either dual 2 or dual 4 ohm. You need to either check if the sub has it printed on it or test it with a multimeter to check its resistance.
2. Each channel? The amp is single channel it only has 1 channel.
3. when 2 subs are connected it will only provide 600wrms total
i made a mistake in the first post
the amp is
2ohms Load Mono = 600 watts x 1
NOT 2ohms Load Mono = 600 watts x 2
my sub says its 2 ohms dvc
anyway
1- this amp is a mono block one, one channel ???
but it has 2 outputs for 2 subs doesnt that make
it 2 channels ???
2-so 2 kicker solo baric l5 subs are too much for this amp ????
one sub is enough ???
3-a sub with more WRMS will be better or the same
coz the amp only provides 600rms
4-if i put these kicker subs both of them will recieve 600rms
or each one will recieve 600rms???
5-is there any better sub which would bang my trunk better ??
sorry for all these questions
but im a noob //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
thnx yall
i made a mistake in the first postthe amp is
anyway
it 2 channels ???
thnx yall
ok so the first part makes no sense at all, there is no 600watts x 2, there is just 2 output terminals for EASIER speaker wire connections
1.any MONO block amp is 1 channel, hints the name mono meaning single
2. a single sub would be fine, I dont know how under-rated the amp is but I imagine 800watts rms at 2ohms so it would be like 400 watts per sub at that point
3.that sub is fine for the amp, u generally want the RMS to match or get an amp that has a higher wattage than the sub so your gains dont have to be all the way up causing clipping
4. its a MONO amp, one channel, they will SPLIT the over all power, if the amp is maxxed out at power it might make 800-850wrms
5. use that sub as a learning experience, do your research and learn before u buy something new, let this one kind of be your foot in the door
no offense or anything but you have a LONG ways to go before stepping up to bigger systems, spend your time here, read alot and use search, it will help avoid u getting ignored or yelled at
Im not trying to put u down, I still have a long ways to go to learn also but the most important part is research, this website has everything and more than u will probably ever need to know, start off with the easy stuff and work your way thru the list eventually. its defiantly not a one day thing
http://www.bcae1.com/
jojo1212
jojo1212
ummm
jojo1212
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
