Description
Rec. Sealed Box Dims: 1.00 cu.ft.
Rec. Ported Box Dims: 2.00 cu.ft.
Free Air Usage: not recommended
Sensitivity: 91 dB
Frequency Response: n/a
Recommended RMS Power: 700W
Peak Power Handling: 1400W
Impedance: dual 4 ohms
Non-Pressed Paper Cone
2-Piece Die-Cast Aluminum Basket
Diamond-Cut, Metal Flake Royal Blue Finish
Black Spider with Woven Tinsel Leads
2" BASV Voice Coil
1-Piece EVA Rubber Mounting Gasket
Heavy Duty Binding Posts
Large Roll Treated Foam Surround
Mounting Depth: 6.3"
Mounting Diameter: 9.33"
Description
Rec. Sealed Box Dims: 2.00 cu.ft.
Sensitivity: 93 dB
Recommended RMS Power: 800W
Peak Power Handling: 1600W
2" BASV Voice Coil
Mounting Depth: 8.1"
Mounting Diameter: 14.125"
here are the specs, for a 12 and a 15. thanks.
