I need some confirmation on a summer project...
Aphix
I have 2 12" Kicker Comps and have been lookin for a summer project, so I decided to up by bass effects with a ported box! my trunk dimensions are Width-43 Height-18 and Depth-30 (or Height-15 and Depth-34). The subs require 1.75 ft3 of space each. Im pretty sure the box plan I have will work but I figured I might as well check with you guys before I run off to Home Depot. The link to the box I think will work is here http://img10.imageshack.us/my.php?image=35cubes35hz54sqin9ij.png. Am I missing anything? Thanks in advance
Thatd be great if I could have some. This is just a daily driver car but I know kids with those $40 pioneers who are hitting harder than mine and I wanted to up the bass. My trunk dimensions are Width-43 Height-18 and Depth-30 (or Height-15 and Depth-34). The subs require 1.75 ft3 of space each for a ported box. Thanks for all the help Im not much of a ported enclosure pro.
here's what i came up with....
total vol.: 4.75cu' (i gave each sub 2cu' and accounted .25cu' for each sub and .25cu' for the port)
tuning freq.: 34hz
port area: 27sq"
cut sheet
box
-top/bottom: 18" x 36"
-sides: 18" x 13.5"
-back: 36" x 15"
-front: 15" x 17" (x2)
port
-13.5" x 8.75" (x2)
remember, the port walls go inside the front pieces. the 8.75 long pluse the .75 for the thickness of the front equals 9.5 total length.
any q's lmk....
Aphix
Aphix
Eagle, Nebraska
Aphix
michigan born
    May 14, 2026
michigan born
    May 14, 2026
