i need some advise, should i buy these? or am i getting riped off? my first sterio
boilomonster
Frekvens : 35 Hz - 250 Hz
Max (RMS): 800 Watts
Max (pink noise): 1600 Watts
Impedans: 4 Ohm
Dimension: 46.6 cm x 69.2 cm x 90.3 cm
weight: ca. 49,2 kg
i have two of these subwofers
and i've got two of these
XVP-2520
Frekvens: 45 Hz - 2550 Hz
Max (RMS): 450 Watts
Max (pink noise): 900 Watts
Impedans: 4 Ohm
Dimension: 49.7 cm x 54.5 cm x 110.8 cm
wheight: ca. 41 kg
al of it together costs 1200 dollars and they MAX 5000 watt
and i got a van so the space ain't a problem.
anny advise will be appreciated
I don't even know what kind of subs those would be, the specs seem suspect. I can't think of any speaker that weighs 110 pounds, let alone to only handle 800 watts. So, what kind of speakers are they?
And what's "Norge"? Is that like Norway? If so, what's 1200 US dollars even come to there? Don't you guys use the Euro?
Nvm, I just looked those bottom ones up. I don't have a clue about PA system speakers, maybe you should check out a DJing forum or something?
boilomonster
boilomonster
Norge
boilomonster
