I need a 5 Channel Amp comparable to the Hifonics Brutus BRX5000.5
nyg052003
Can you guys help me out with finding a comparable amp. I decided on the Hifonics brx5000.5 but its no longer offered it looks like. I'm going to be running a Polk audio 6 1/2 component set, a set of kicker 6x9 3 ways, and 2 10 inch maybe Sound audio E series subs.
I've got some Ground Zero Hydrogen 5 channels available.
Specs:
Output Power @ 4 Ohm (CEA*)4 x 100 & 1 x 430 W
Output Power @ 2 Ohm (CEA*)4 x 150 & 1 x 430 W
Output Power @ 1 Ohm (CEA*)Ch 5: 600
Bridge mode ch1-4 2x400W
I also am looking to a price comparable to the Hifonics //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I will check the links you guys provided and compare.
the memphis big bell amp listed is a 10x better then the hifonics. One of the best 5 channels made.
soundstream's a budget choice.
ground zero is awesome too if you have the money for it.
Specs:
I'd like to have for the sub, at least 1000x1 @ 1 ohm. I say 1 ohm because it seems most amps in the price range i'm looking for can't produce that much power at more than 1 ohms. As for the other 4 channels 60-100 is fine.
5 channel?
price?
I need something around 60-100 or so for the 4 channels for my hi's and at least 1000x1 for the sub. I'm going to run 2 10's.
the brown seat isn't my car. I hope that that my seat is long enough to mount the memphis if i go with it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it's 2 ft long
Read the links listed above man.
yeah i just saw it after I had already asked you about it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
from the soundstream amp to the memphis, Soundstream 750 @ 1 ohm for sub vs the 1100 for the Memphis, I guess i would notice a difference in how my system sound from one amp to the next?
comparing getting one or the other
what if I wan this AMP with a P2 Rockford sub https://rockfordfosgate.com/products/details/p1000x5/ Had one shop quote me at 1100 for everything...
15
4K
451
355
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
393
nyg052003
nyg052003
charleston, SC
blazeplacid
    May 31, 2024
    May 24, 2024
