I know how to hook it up but I have no idea what to buy.
jgeezy
I have a 2009 Jeep Patriot without the Boston Aucoustic Sound Sytem and I would like to upgrade my sound system.
What I want: I want to be able to hear mids and highs and I want to have a decent amount of bass. I dont want to bump the neighborhood but I would like to feel it a little bit. I am wanting to work with an 8 inch subwoofer.
JVC KW-R910BT is the head unit I really like. I guess I dont really care as long as its a double DIN and can do bluetooth audio and bluetooth streaming.
All 4 doors take 6x9's
I need speaker suggestions, amp suggestions. for both speaker and sub
I have about $600 to $800 to work with and that price needs to include all of the adpaters and wiring kits in it.
Can anyone help?
find some suitable 4 ohm 6x9 speakers to replace factory - then run them to the amp as front and rear driver door = left channel - front and rear pasanger door to right channel = the amp will have 2 ohms load. if you get a 4 channel amp then you can bridge the last 2 channels together to run your single 8" sub that will need to be dual 2 ohm coils to wire to 4 ohms load at the amp in bridged mode.
doing this should leave you enough $ left over for your headunit - and adapter pieces.
im fairly certan all the speaker snobs will tell you that 6x9 are the worst - and to use adapter plate to just run 6.5" round speakers...
jgeezy
jgeezy
Aldeson, WV
UGHH
