I know how to hook it up but I have no idea what to buy.
  • 4
jgeezy
I have a 2009 Jeep Patriot without the Boston Aucoustic Sound Sytem and I would like to upgrade my sound system.
What I want: I want to be able to hear mids and highs and I want to have a decent amount of bass. I dont want to bump the neighborhood but I would like to feel it a little bit. I am wanting to work with an 8 inch subwoofer.
JVC KW-R910BT is the head unit I really like. I guess I dont really care as long as its a double DIN and can do bluetooth audio and bluetooth streaming.
All 4 doors take 6x9's
I need speaker suggestions, amp suggestions. for both speaker and sub
I have about $600 to $800 to work with and that price needs to include all of the adpaters and wiring kits in it.
Can anyone help?
find some suitable 4 ohm 6x9 speakers to replace factory - then run them to the amp as front and rear driver door = left channel - front and rear pasanger door to right channel = the amp will have 2 ohms load. if you get a 4 channel amp then you can bridge the last 2 channels together to run your single 8" sub that will need to be dual 2 ohm coils to wire to 4 ohms load at the amp in bridged mode.
doing this should leave you enough $ left over for your headunit - and adapter pieces.
im fairly certan all the speaker snobs will tell you that 6x9 are the worst - and to use adapter plate to just run 6.5" round speakers...
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
jgeezy
jgeezy
Aldeson, WV
UGHH
    May 18, 2024
    May 18, 2024
