i installed my headunit... but its not working!!!
954runner
just bumpin my music
i just put my eclipse 8445 in my 08 versa and its not working!
the ESN on the hu isnt activated, and all the wires are hooked up correctly (power, acc, ground, etc) except for the power antenna cord.
w the versa, you have to get an antenna adapter to plug in the antenna, which has a power cable connected to it.
i tried plugging the power antenna cable into the existing power wire on the plug, but it did nothing.
should the headunit work w the adapter? i ordered it today, but could that be causing it to not work? help me please!!!
i just put my eclipse 8445 in my 08 versa and its not working!the ESN on the hu isnt activated, and all the wires are hooked up correctly (power, acc, ground, etc) except for the power antenna cord.
well, first off, your unit isnt wired up completely......
secondly, check the voltage of the constant power and ignition power with a DMM
thirdly, check for any blown fuses
i checked w my DMM and the 12v constant reads ~14 volts and the acc is reading ~.75 volts. is that the problem??? how can i fix it? i'll recheck fuses
If you didn't use the Nissan Diversity Antenna Adapter, that is the problem. Nissans use several grounds including one through the antenna. If your wiring is 100% correct, the problem will be solved after you use the Nissan Diversity Antenna Adapter.
.75 v means you have a blown fuse in the car.
Also the diversity antenna has nothing to do with the unit turning on. You wont get any fm reception without it but it will not affect actual powering of the unit.
so the cord on the antenna adapter is a ground and doesnt connect to the power antenna cord on my headunit?
NO! Nevermind, I thought you had a standard Nissan Diversity Antenna Adapter. I guess the 08's are different. That wire should be for the power antenna +. I just meant normally if the antenna adapter isn't plugged into the antenna HU's in modern Nissan's won't power on.
954runner
954runner
Dallas, TX
954runner
Mike Mccabe
