I Have A 15'sub In A Sealed Box,can I Put A Ported One Also For The Spl
  • 4
if the manufacter says to put the sub in a 1.0 cu ft PORTED box
go for it
but usually to get better sound... the ported box has to be bigger than the sealed one
i dont think u will be happy with the sound if u just port it
go get a bigger ported box or just leave it as is.. u say it hits hard already
but i wouldnt port that small of a box for a 15
Originally posted by COMP-X MY COMP-X SUB IS IN A 1CUBFT SEALED BOX AND IT HITS HARD,BUT I WANT TO PUT A PORTED BOX ALSO FOR THE SPL STUFF WITH ANOTHER COMP-X SUB??IS THIS A GOOD IDEA OR WILL IT MESS THE SOUND UP?????
You mean you want to put another sub in there with the existing one in a ported box, having one sub in a sealed and one in a ported? That would probably sound like ass;)
Puttin sealed and ported together is a big:nono: This will result in lots of cancellationwhi will then =Crappy Sound.
oh and please take off the caps from now on, it annoying really it is.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
  • Locked
If you're available... please dm me. I'm interested in chatting about this box. Hopefully it's still for sale. Thankyou
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
241
COMP-X
COMP-X
GREECE
80_Cutlass_mn
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
