Box Quest?
  • 4
TRANSAMCHARGER
Alright im sellin my old stuff to get 2 brahmas. Im buying 1 at a time, so i wanted to know if i go ported could i run 1 sub in the dual box(is there a divider between the 2) Also if i go ported i wanna know how big i should go, size not a problem, i was thinkin lik 8 cu ft, i dont know, have 96 gran marquis, and how much would the box cost.
u can build the box for about $50 i think it would be fine to just run one in one side alongas there is a divider dont worry the brahmas should tell what cu.ct. is needed for a ported box going with sealed though u can push more through them but ported will let it move more freely
porting two chambers is hard because you need to get the EXACT same tuned frequency, not saying its impossible, but just would not recomend it if its your first port job. You could also just not cut out the hole for the second one, port it as one big box and then cut the second hole (the tunning frequ will change a bit since you are loosing the volume of the second magnet inside the box, but the difference should not be great.
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
411
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
760
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
601
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
Go get some shitty wood or cardboard or something and figure out what the max is, play around with different dimensions to see what the max cubic...
23
TRANSAMCHARGER
TRANSAMCHARGER
Conneticut
Randy Savage
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
