Sealed 15' Sub In A 1.5cubft Box Instead Of 1.0cubft????
  • 2
COMP-X
24
GREECE
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif I HAVE A 15' COMP-X SUB[800RMS] IN SEALED 1.5CUBFT BOX,BUT IT SHOULD BE PLACED IN A 1.0CUFT.....THE 1.5 BOX IS FOR PORTED..BUT IT HITS HARD AND MAKES YOUR EARS BLEED EVEN IF IT IS .5CUFT BIGGER!!!! WOULD THIS CAUSE DAMAGE TO THE SUB??
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
  • Locked
If you're available... please dm me. I'm interested in chatting about this box. Hopefully it's still for sale. Thankyou
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
COMP-X
COMP-X
GREECE
Sinister86
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
