At 1 ohm... You should have bought and amp first lolwell i cant afford that right now but you dont tink a ac3000(planet Audio) will do the work ? it says rms 3000
I agree! my first system consisted of a boss 2500w amp for $100. I thought i was tha shiz.....till i hooked it up.....Don't be cheap an spring for the ZX1500.1. You will thank me later. It does 1500+ ACTUAL WATTS (read: RMS) and it does this at a final 2 ohm load which is exactly what you need. You might be able to find the 08 models a little cheaper now that the newer ones are out, but they are just as bulletproof. Don't skimp out on what could possibly be the most important component of your system.
if theyre dual 2 ohms, im guessing yes...unless he wired em to .5 ohms, which in this case will fry whatever amp he buys especially that planet audioIs it a 2 ohm final load or wtf
if you want to go cheap, fine a used hifonics BRUTUS serious, and will be able to handle .5ohm, i havent had a problem with my old one at .5ohm. just dont turn the gain to the end and you'll be fine. audiopipe, audioque will be fine too....fuck planet audiook thank you everyone haha
