I have 2 12" l7 kickers in a stock box.
Don't be cheap an spring for the ZX1500.1. You will thank me later. It does 1500+ ACTUAL WATTS (read: RMS) and it does this at a final 2 ohm load which is exactly what you need. You might be able to find the 08 models a little cheaper now that the newer ones are out, but they are just as bulletproof. Don't skimp out on what could possibly be the most important component of your system.
I agree! my first system consisted of a boss 2500w amp for $100. I thought i was tha shiz.....till i hooked it up.....
I say wait and buy a good amp. Even a kicker zx1000, i think would be better than that amp youre looking at. and there's one for cheap in the classifieds here or on caraudioclassifieds (cant remember exactly)
plus u called kickers rms rating on their subs bs, but u went and looked into "3000 watt" planet audio amp. there's a bs rating in there, but its not where u think //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
ok thank you everyone haha
if you want to go cheap, fine a used hifonics BRUTUS serious, and will be able to handle .5ohm, i havent had a problem with my old one at .5ohm. just dont turn the gain to the end and you'll be fine. audiopipe, audioque will be fine too....fuck planet audio
A set of rounds in all of the doors, not the front or the front and the rears, with the dash speakers, no mention of the rear doors, didn't...
797
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
757
919
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
592
mailbukicker
mailbukicker
Long island, NY
gvegaz
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
