I got some few Questions! I need some Anwsers ASAP!! Thanks!!!
nofriends46
I have a Soundstream rubicon 204 (25 x 4), hook up to an Profile electronic crossover that has a front and sub input, mid,high,sub & full output. My head unit, had sub, rear and front output, so my sub and front output from my HU goes to the sub and front input in the Electronic crossover.
My tweeters are hook up to my 1 & 2 channel and my regular coxial speakers are hook up to channels 3 & 4. So my electronic crossover, my high output goes to 1 & 2 and my mid output goes to 3 & 4. When i remove channels 3 & 4, my regular speakers work still, what seems to be the problem?
I thought when i remove it, there will be no sound at all?
What is Local and Remote for my Soundstream Rubicon 204? i want all the channels work, not only one. How do i do that?
Also when i figure out the problem, what do i set my mids and highs?
I got some questions from my electronic crossover
What is Phase 0 - 180 degrees?
Input DR - MIX?
Mode ST - MO?
ouput level?
When i installed my electronic crossover, my highs are not that high anymore? Before i installed it my highs sounded fine.
Also i have some egine noise going on, i have a book to figure it out. Hopefully i do.
Any suggestions, should i take my electronic crossover out, or just leave it in?
My regular speakers are connected to bass blockers. Thanks for you patiences!!!!!
Originally posted by nofriends46 I have a Soundstream rubicon 204 (25 x 4), hook up to an Profile electronic crossover that has a front and sub input, mid,high,sub & full output. My head unit, had sub, rear and front output, so my sub and front output from my HU goes to the sub and front input in the Electronic crossover.
I don't understand want you saying? regular speakers?? you mean the coxials? and remove ch 3&4? you mean unplug the RCAs?? from the amp OR x-over
depends on the wiring
aside from the turn -on REMOTE wire I don't know
what are the options?
That phase refers to normal-0 or reversed-180
Input DR - MIX?
Dirrect OR mixed..... you want dirrect and the mix will mix sounds from the other channels
Mode ST - MO?
stereo OR mono---- you want stereo as mono mixes both left and right
ouput level?
this is from gain matching the next down stream processor or amp.
I can help with the noise when you post back your problems and answers
we didn't trouble shoot yet how can you ask?
you will not need that after we get your x-over strait
nofriends46
nofriends46
Hawaii, Kauai
Roberto
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
