FEATURED Hyundai Cilantro.. I mean Elantra!
Productive day off today. Still got paid, got my AGM battery and my floor mats.
Out with the old...
In with the new!!!
I just ordered a 10T handheld hydraulic crimper. I have replaced the battery so next is the 200a alternator to which I will run a 0awg cable to from the battery. The problem is, I don't like these battery terminals or the use of allen screws for everything. I will be getting some new terminals with 4 ring terminal connections on each of them. So I will take every wire and cable that touches the battery and make new connections with the crimper and ring terminals. 12v+ side will be copper ring terminals and the 12v- side will be silver colored copper ring terminals, all with heat shrink. Should look good and hold better too.
I somehow blew my triple trumpet air horn in the grill of the Elantra. The relay is corroded and shot and I think it caused the mini compressor to poop the bed. I ordered a single 18" trumpet to replace the current triple horn setup. New trumpet, new compressor, new relay, new wiring. This one is black instead of red so it will disappear behind the grill better.
This is the one.
I ordered the new terminals today. Interesting design. I think the concept is good. Each terminal has three 0awg slots on each side secured with the allen bolts going through the nuts on top... which are for ring terminals. These terminals are pulling double duty!!
Looks like they have terminal shims in there too. Link?
I'm just buying **** now lol. I just ordered an RCA Y cable - two female to one male. Knukonceptz Krystal series. The Taramps Smart 3 has 1 RCA input. I don't think these Punch P3's are gonna handle it.
Im always guilty of Just buying man. Seems Like an Addiction of car audio for me???
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
219
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
494
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
668
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
spokey9
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
