FEATURED Hyundai Cilantro.. I mean Elantra!
Man those look real similar to these on temu 🤔
It's worse than I thought. I was watching my voltage gauge as I played some music. Volume goes to 40 undistorted. I can turn it to 26 all day and be fine. The gauge stays around 13.9v - 14.2v on music. If I go above 26 into the 30's where I like to jam bass music the gauge was droppin into the 10's of volts. Thatsa no goooood. I will prolly add an additional second, identical battery after the H.O. alternator.
AND.... had to replace the replacement alternator last night. I wasn't even playing my music loud. Started out on the drive to work. My dash lights seemed dim... I just figured it's 5:30am, I am still sleepy. After work my windows were slow to roll up and down. Halfway home the bass cut out... then the CEL came on.... then the airbag light. Turn signals would not show up on the dash. When I parked it still 45min from home she would not restart. I lowered the back seat. The voltage was 8.9v on the stinger. YIKES!!! Luckily when I had the battery tested after the new alternator install it was still good but only 53% charged. The 200+ amp alt is coming soon and I have the removal and install down to 20min.
Just installed the new A/C controls and while that was out I installed a small 12v voltage meter on my dash above the radio. It is reading direct battery voltage and is tapped into the cigarette lighter plug. Car on 14v, off 13.2v.
I've been dragging azz to install one those 😂
This new voltage gauge is really delayed but it works. You can see why I need the 200+a alternator. Sorry for the dark and blurry video... it's night time and the camera is sub-par.
  • 20240211_183732_x264.mov
    14.8 MB
Hey if I get one of these Ioxus something something 31 Ultra Capacitor... do I fuse that thing? The chain is finna be (under the hood) the 200+a alternator - Die Hard Group 124R AGM - (in the back ) Ioxus Ultracapacitor group 31 just before the amps.
I have a 300a Circuit Breaker on the firewall under the hood and fused distribution with mini ANL fuses out back. Talk to me guys!
Id probably fuse based on the max charging amp rating
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
656
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
592
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
778
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
744
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
12
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
Doxquzme
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
