Hunterw's 87 mazda b2k build *revised*
whooodie whoooo.....turn it up **** it! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
well shit....i knew i forgot to do something //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
hey hunter sick score btw
on that recone did you end up bolting the landing down, or just glue it?
and how do you know when its far enough to glue the cone to the former?
i bolted her down. BUT the best thing to do is....to predrill through the spiders, then sink the screws. its much easier that way. and on the second question....will you reword that? i m tired and dont get it lol. but i used activator on the glue on the spider landing to speed up the process lol.
well I got a motor from sqcrewcab, and I think im gonna grab one of his 10" recones to play with before I recone it to an 18
But what i was meaning. The cone and the former are not glued together right out of the box, so how do you know where to glue the cone to the former?
I have only done dd/aq recones and they are all one piece
thanks man, I appreciate it
what recones do you have too? 55mm, and 3 spider?
oh i see. what i do is, do the triple joint last ( cone to former joint) i put the cone on, where the surround is touching the baskets landing, and glue the cone to the former on the inside of the cone.let it dry and then do the surround and then just tilt the sub and get in there real deep like and put a bead around the cone/spider joint. if that makes sense. honestly....remember to line up the bolt down ring and predrill will a small bit, then sink the screws. it will prevent the ring from sliding after you have the ring off and the shims out, and it also prevents you from seperating the spiders when trying to screw the screws in.
sounds like it could be a pain the ***:crap:
I appreciate it bud. I will def take all those into consideration.
sorry for dumpin on yur thread, but what glue do you use too? and how does that recone play music and handle the d9?
thats the end of my rant:laugh:
na its not dumping buddy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i actually used DD glue. i got it for dustcaps, but i had so much of it i did all 3 recones with it, and still have enough to do another lol.
i havent played music on them yet/if i ever do, but they giggle at the d9s still lol. less then 1.5in of movement. im going to clamp power tomorrow. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif man those d9 amps are stout too........25 each and they do awesome man. i put them in protect a few times, testing volume/amp settings, but they turned back on every time with no problems lol. i will be pulling deadener off tomorrow and testing....i think pulling deadener will get me a much better number
hunterw
whooodie whoooo
hunterw
farmington, NM
hunterw
