Huge Wiring Problem
  • 1
Sem2005
TX
Here is my deal......
I have a MTX81000D and a HiFonics6400 4 Channel amp. The MTX takes 1/0 guage wire and the HiFonics takes 4 guage. The MTX says it needs an external 150 AMP fuse, does it already have a 150AMP fuse in like the Hifonics has a 70 AMP Fuse? How will i wire this system and what are the things that I will need? Where do you get 1/0 guage wire? Can a circuit breaker take the place of fuses under the hood? and then on top of that do i need more fuses for the amps? I don't know much about this stuff and I need some help, so please reply.
Thanks //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
oh alright have you ever worked with the mtx? are you positive it will work, is there anyway to just feed it the 1/0 guage wire?
Makes sense when I went to pay wiring the car audio guy said get 12 guage so I did but I really wanted 8 guage I might just go get another 25...
34
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
116
365
359
Sem2005
Sem2005
TX
Sem2005
    May 18, 2024
    May 16, 2024
