Huge Voltage Drop Help
KickerDawg
ok this is probally gonna be a stupid question. first all i know no one likes caps who cares i did the big 3 i have my regular car battery and 2 diff size yellow tops in back and a 1.5 farad cap and my cap drops to 9.6 and everylight in the car dimms big time what could be going on it didnt start till i added the bigger yellow top which makes no since
are all your batteries new? unhook the last yellowtop and see if you still have voltage drop...
you may have a bad cell in one of your batts...
and get rid of the cap.... it is only good if you already have a super awsome electrical , and just want to stabilize the voltage.....caps become a parasitic draw when your electrical isnt up to par...
are all your batteries new? unhook the last yellowtop and see if you still have voltage drop...you may have a bad cell in one of your batts...
and get rid of the cap.... it is only good if you already have a super awsome electrical , and just want to stabilize the voltage.....caps becomes a parasitic draw when your electrical isnt up to par...
i bought all new at diff times
i think your problem is that your alternator isnt big enough. test the voltage out of the alt, it should be at 14V. Because your small stock alternator is trying to charge your 3 batteries and a cap
Well then what do you think the problem could be dumazz, unhook the big yellow top and try it out!!! if you only make one change and voltage goes funky, pretty obvious to pinpoint the problem
fuken duh
i did unhook it and is still the same could that battery of done something
KickerDawg
KickerDawg
Bloomington,IL
WOT
