HU wiring help..
Tone415
A.K.A FrisnoG
I have 3 wires left on the cars harness, and 2 wires left of the HU harness..
HU harness:
Red-Acc.
Blue w/ White line-Remote
Car Harness:
Orange-Ill. Dim
Red-12 Volt Ignition/Switched
Blue-Power Antenna
In this case does red go to red and blue go to blue and the orange jus gets cut off?
dont need the orange one, the blue/white on the HU is the amp turn on wire.. your gonna need to wire your amp turn on wires to here AND the power antenna, the HU will tell the power antenna to rise up when the HU is on
do you already have your yellow constant and red switched wire from the HU harness connected to something? if so you dont need to connect the other wires i wouldnt think, but if you dont go red to red.
I hooked up the HU yellow-battery to the Car Harness yellow-12 v bat/constant
so red-red, and blue-blue right?
yes and make sure if you have amps, you wire the remote wires to the blue
if you do that, and the HU doesnt turn on.. tke the red switched wire from the HU harness and extend it to your fuse box, you can either use an add-a-fuse or fuse tap, or make your own fuse tap, what you would do is just take a fuse that runs hot ONLY when the car is in the on position, such as sunroof, moonroof, windows ect. and pull the fuse, wind raw wire from the red wire around the fuse and pop it back in (id use an add a fuse or fuse tap though, just to be safe) and test it, it should work.. i had to do this for my grand am.
ahh ok. thanks yo.. ill be back if that doesnt work hahah
Tone415
A.K.A FrisnoG
Tone415
San Francisco, CA
DB-Audio
vegang
vegang
